- First download a copy of the Cyberbit font from here.
- Now download a copy of John-Mark Bell’s font converter from here. Extract the program using !SparkPlug.
- Load TTF2f, and Select-click on its icon to open the dialogue box.
- Drag the Cyberbit file icon into the top writeable box, and change the RISC OS name to Cyberbit.
- Click on the drop-down menu, and select !Boot.Resources!Fonts as the destination for the converted font.
- Now click on the Convert button.
Do NOT assume that the program has crashed, and hit the On/Off button. Just be patient, and wait for it to finish. - Now download the Fonts (Unicode Font Manager) module, from the Video section of the downloads area of the RISC OS Open website, and get ROMFonts as well.
- Extract Fonts and RomFonts, using SparkPlug.
- Find the !Boot application on your hard drive, hold the Shift key down, and double click on it.
Drag Fonts and ROMFonts into PreDesk. - Create a little Obey file with the following two lines -
and save it in PreDesk.RMEnsure ROMFonts 0.75 RMLoad <Obey$Dir>.ROMFonts
RMEnsure FontManager 3.66 RMLoad <Obey$Dir>.Fonts - Do Ctrl-Shift-F12, (or select Shutdown from the Task icon on the iconbar), to reboot your computer.
- Now, load NetSurf and head on over to the webpage of Nippon Television, to check you’ve got it working properly.
Unicode and !PDF
For The Future
