Audio news quickie |
Enzo (09:56 17/8/2011) Enzo (10:50 17/8/2011) helpful (11:15 17/8/2011) Enzo (11:26 17/8/2011) trevj (11:28 17/8/2011) Enzo (11:31 17/8/2011) Jacko (09:34 20/8/2011) Enzo (07:04 22/8/2011) MEmerton (21:58 8/10/2011)
Xavier Tardy |
Message #118475, posted by Enzo at 09:56, 17/8/2011 |
That's great news ! The sound is superb, it's easy to use. I'm really happy to have this kind of apps on RISC OS.
There is an extra feature I'd be very happy to see added : the ability to load zipped files, letting the player decompress them.
It would save a lot of space on hard drives. (Yes I know I could burn a CD)
Anyway, a big thank you to the author. Great job !
[Edited by Enzo at 12:34, 17/8/2011] |
Xavier Tardy |
Message #118476, posted by Enzo at 10:50, 17/8/2011, in reply to message #118475 |
I'm trying to have some plug ins working but to no avail. I've copied them in !DCDRes, creating the directories PlugIns and inside it FullScreen for example as needed for Cthugha, but to no avail.
I've double clicked on !DCDRes. Checking the documentation it says the directories PlugIns and PlugIns.Desktop + PlugIns.FullScreen should have been created but well, no.
'Misc' in the control panel of !DigitalCD displays 'Start plug-in' and 'Stop plug-in' as not available.(greyed)
Middle click on the !DigitalCD icon on the iconbar, 'Choices...' displays a window where 'Plug-ins' show 'Samplers' and nothing more.
Thanks for your help.
I'm using an Iyonix.
[Edited by Enzo at 12:09, 17/8/2011]
[Edited by Enzo at 12:29, 17/8/2011]
[Edited by Enzo at 12:29, 17/8/2011] |
Bryan Hogan |
Message #118477, posted by helpful at 11:15, 17/8/2011, in reply to message #118475 |
There is an extra feature I'd be very happy to see added : the ability to load zipped files, letting the player decompress them. Fairly unnecessary on RISC OS with its image file access to zips as if they are directories anyway. |
Xavier Tardy |
Message #118478, posted by Enzo at 11:26, 17/8/2011, in reply to message #118477 |
Well, it's an extra double click ... (ok I'm lazy). |
Trevor Johnson |
Message #118479, posted by trevj at 11:28, 17/8/2011, in reply to message #118477 |
the ability to load zipped files, letting the player decompress them. Fairly unnecessary on RISC OS with its image file access to zips as if they are directories anyway. True, but it would save an extra double-click. Consider a directory full of zipfiles containing just one tune each (which is probably how they are distributed on the internet) rather than zipfiles containing numerous tunes. |
Xavier Tardy |
Message #118480, posted by Enzo at 11:31, 17/8/2011, in reply to message #118479 |
the ability to load zipped files, letting the player decompress them. Fairly unnecessary on RISC OS with its image file access to zips as if they are directories anyway. True, but it would save an extra double-click. Consider a directory full of zipfiles containing just one tune each (which is probably how they are distributed on the internet) rather than zipfiles containing numerous tunes. Thanks. It's exactly why I'd have been happy to see this new feature added.
Could you try to install some plug ins on your machines and tell me if they work ? thanks in advance. [Edited by Enzo at 12:32, 17/8/2011]
[Edited by Enzo at 12:33, 17/8/2011] |
David Jackson |
Message #118481, posted by Jacko at 09:34, 20/8/2011, in reply to message #118480 |
{Middle click on the !DigitalCD icon on the iconbar, 'Choices...' displays a window where 'Plug-ins' show 'Samplers' and nothing more.}
clicking on 'Plug-ins' gives me the choice of desktop or full-screen plug-ins, also enable plug-ins |
Xavier Tardy |
Message #118482, posted by Enzo at 07:04, 22/8/2011, in reply to message #118481 |
Problem solved. Don't know exactly what I did but it's ok now. Strange. |
Michael Emerton |
Message #119029, posted by MEmerton at 21:58, 8/10/2011, in reply to message #118475 |
I have just noticed that the latest DigitalCD is: DigitalCD 3.03 (27-Sep-2011) on the downloads page! |
