- Next developer fireside chat (News:)
- DDE31d released (News:)
- South-West Show 2024 Report (News:)
- South-West Show 2024 in pictures (News:)
- !Organizer reaches 2.26
- RISCOSbits updates FAST ROM
- WROCC Newsletter Volume 41:10 reviewed
- The Book of Draw Stuff reviewed
- WROCC Newsletter Volume 41:9 reviewed
The Icon Bar: News and features: !DualHead in use
!DualHead in use
Posted by Mark Stephens on 06:20, 8/9/2017 | ,
  !DualHead in use
  nytrex (01:15 11/9/2017)
  jimnagel (14:57 14/9/2017)
    arawnsley (20:31 14/9/2017)
      riscosbits (22:38 14/9/2017)
      Elesar (08:28 15/9/2017)
        riscosbits (09:43 15/9/2017)
Alan Robertson Message #124149, posted by nytrex at 01:15, 11/9/2017
Great to see developments like this.
Jim Nagel Message #124152, posted by jimnagel at 14:57, 14/9/2017, in reply to message #124149
What happens when an error box pops up? It would normally be in the middle of the screen, so does it fall at the borderline between the dual screens?
Andrew Rawnsley Message #124153, posted by arawnsley at 20:31, 14/9/2017, in reply to message #124152
There are pros and cons to both approaches - one big screen (eg. 3440x1440) on ARMX6 or dual monitor on TiMachine. For a start, two smaller monitors are cheaper than one 34" ultra-wide. As long as you use thin-bezel monitors, it shouldn't be a big issue. On the flip side, one big monitor is probably simpler for RISC OS .
RISCOS Bits Message #124154, posted by riscosbits at 22:38, 14/9/2017, in reply to message #124153
[Edited by riscosbits at 10:40, 15/9/2017]
Robert Sprowson Message #124155, posted by Elesar at 08:28, 15/9/2017, in reply to message #124153
In principle !DualHead could be extended to add a Wimp filter that spots windows trying to open centred, and move them to the left (or right).
Dell sell a quad picture by picture monster https://www.engadget.com/2016/05/23/dell-43-inch-quad-monitor/ though 43" may require buying a bigger house first!
RISCOS Bits Message #124157, posted by riscosbits at 09:43, 15/9/2017, in reply to message #124155
I really like the "where your eyeballs are" idea, but would prefer an option to not do that, in my "one screen" situation.
And a bit added on to the mortgage!
